1988 Johnson 50 Hp 2 cylinder VRO
cdejlitko
I'm not sure what else to look at.
Power pack maybe???
Carb spitting video.
https://youtu.be/Ig95K9LPc2M
1988 Johnson 50 Hp VRO runs for about 20 seconds and dies. It's spitting through the carbs. Starts right back up. Bogs down on acceleration and surges.
I have rebuilt the carbs(fixed jets no adjustment) I put clear fuel lines to the carbs and they never loose flow, compression test 115 psi on both cylinders. Replaced reed valves (because there were seven reeds not seating)and intake gasket, new fuel pump and eliminated VRO, coils ohmed and tested ok, new Champion spark plugs and wires, primer ball has good pressure and doesn't change anything if I pump it while it's running, Fresh mix gas, sea foamed thhttps://youtu.be/89e9h_WPmgwrough carbs.
Any help would be appreciated. I'm ready to give up.
Honorary Supreme Mariner
Checked flywheel key ?-----Do you have spark on both leads ?---My compression tester would show 140+ on a good motor like that.
