blacksmith82
Thread starter- Joined
- Jun 23, 2009
- 11
Hi,
I have a 1988 Johnson 4hp (J4RCCS) that will not pump water. I have replaced the entire water pump assembly including the housing, plate, impeller, etc. This motor discharges water through holes in the leg. When I first replaced the assembly it pumped water through the holes in a steady stream for a few minutes, and then it just stopped. Since then I have gone through everything I can think of and I can't seem to get it to pump again. I removed the powerhead to see how the water flows and ensure there was nothing clogging it which there wasn't. I can feel some suction at the vents in the lower unit so it seems like the impeller is working. Does anyone have any experience with this motor or any ideas as to what could be causing this? Any advice will be much appreciated. I have spent quite a few hours on this one.
Thanks
Thanks
