purplegrape
- Aug 27, 2013
- 16
Hey everyone,
I have a 1988 Johnson 4 hp outboard (2 stroke).
My issue is that on full throttle she will run for about a minute or 2 and then it boggs down and cuts out. If I cut back on the throttle chances are it will keep running. If it does not than I pull the cord and off she goes again.
I have a new water pump, carb seems good cleaned it well a couple times, compression is good, and I'm using 91 octane gas mixing 50:1 however the motor has a sticker calling for 100:1.
The motor never seems to over heat and will run for sometime without issues at a low or mid throttle. Ive had trouble with the idle needle but it seems to be in a good spot. Just can get her to run full,
Any thoughts?
Thanks!
Any thoughts?
Thanks!
