1988 johnson 48 spl t&t
howard mills
my 88 johnson 48 spl. tilt and trim wont stay up and wont go up under way. the trim motor is operating seems like the hydrolics are weak . it is apprently one of the dealer add on types that mount to the starboard side engine bracket . can they be rebuilt , seals , check valve . something?. if so where to buy parts. H.
bob johnson
Re: 1988 johnson 48 spl t&t
sounds like it is one of these, which I have......
bob
rolmops
Maybe you should just add a little bit of oil. I use regular ATF.
howard mills
bob that is it . whats wrong with it and where do i buy the parts . H.
bob johnson
id start with making sure it is full of fluid...
I am guessing the electricals work..
if you have fluid and it wont stay up, you may need new seals....havent a clue where to start...a BRP dealer...i guess...they list the parts.....so maybe they sell them...
my motor was frozen..i took it all apart.... and cleaned and reassembled...what a pain....havent tried it yet...
good luck
bob
howard mills
good luck
bob
bob what is brp dealer
jerryh5364
Thread I Have the same problem with my Johnson. The Motor goes up but will not stay up .I took it to a friend of min who has a hydralic business for ove 30 yrs and he told me that the seals were bad . The probability of repairing it were almost O ZERO because the Housing was Aluminum and the screws were probable Frozen in the housing and would strip trying to get them out and you couldn't rethhread them for new screwsbecause of the thiuckness of the housing wall. I'm just looking for a new motor and Pump now . Even went to the original dealer where I purchased the boat &they didn't know what to do 'cause theydont handle the boats any more
jerryh5364
bob johnson
that unit the op has is a unique unit.....a standard TNT unit is probably easier to get parts for. I just picked up a motor with a bad TNT unit...two previous owners couldnt get it to work and finally drilled the manual release out!!!
I got the motor took the unit off...and machined what was left of the manul release out and got a used manual realse and installed that. I took the unit apart and the piston seals were great!! all three..the wiper seals were great!!!, the o-rings that were sandwiched between several flat mating surfaces of the unit were all dry rotted... i replaced all those... and put the unit back together...works like a charm!!
my point being..it might just be O-rings...easy stuff!!!
PS for aluminum parts heat helps get bolts out......aluminum will expand!!! you dont need it 800 degrees!!! 300-400 degrees and the casting expands from around the threds of a bolt and you turn the bolt out!!!!
dont get it so hot that seals 4-5" away melt!!!
good luck
bob
