If you're saying that the "steel" pin that the spring is connected to actually pulls out of the "aluminum" vertical throttle lever, You'll need to replace that vertical lever Part #398026... superseded up to part #438075... OR... take that lever and pin to a machine shop. It's beyond the ability of the average boater or mechanic to do anything on a permanent basis otherwise.
