1988 Johnson 28 spl new impellor now two reverse and no forward
Womp63
The wife and I changed the impellor on the 28 hp Spl this week. Got good water flowing now so I took it to the lake. Runs like a beast in reverse but now I only have reverse. Put it in F and still have reverse. I assume that somehow the shift linkage got turned but the problem is that there is no access to the shift linkage behind the water screens as everything that we have researched suggests because this particular motor doesn't have those screens. Our access to the shift linkage is up in the top third of the shaft behind a solid cover. Behind that cover is a flat piece of metal with two small bolts on it. We had to remove the bottom bolt to free up the shift linkage to remove the lower unit. It was a delicate and painful experience to replace the bottom bolt. Any cheats or helpful tips to reassemble would be greatly appreciated.
flyingscott
My guess would be you did not get the shift rod connected correctly. The bolt HAS to go through the slot on the shift rod. If you missed the slot the rod just pulled out of the linkage.
Honorary Supreme Mariner
As above ---You have to lineup the notch on the shift rod with the hole in the connector.-----Failure to work carefully here results in a stripped thread on the bolt or connecter.
