1988 Johnson 175hp no spark ! Help
Heywire77
Okay I have what I bought as a 235hp outboard , on the tags it showed up as a 235hp but after some research I found out the heads are actually from a 175hp and the carbs are 235hp carbs , it is the hump back and I was told the 235 and 175 are both same motors except heads and carbs and a couple other things . My problem is when I first got the motor I was missing the carb silencer so I couldn't hook up throttle and my fuel primer was missing . But I still sprayed some gas in carb and it fired up and ran till it ran out of gas . Okay now to today I got everything hooked up and go to start it and it want start and no spark at the spark plugs on both banks . Also I noticed that my outboard has one CDI unit on it like the newer models and not like the two the older model 235hp take . I have looked up parts for a 1989 175hp and the cdi that is on it doesn't look like the one in the pics , so I'm not sure it is even right or just one they had and thrown own it to sell . My motor spins over good and new battery with good voltage but no spark is there a place to start to check to see if it is the cdi or something else that could be causing it . I have made sure my kill landard and shift interrupter switch are working . But I need wiring diagram and wire to check and procedures on checking the cdi or whatever else it could be . Also is there anyway to find out for sure what motor I have I checked the part numbers on the heads and they came up to a 175hp heads . Thanks
Heywire77
Also it has the the hump back exhaust someone told me it was a gt175 outboard ?
Honorary Supreme Mariner
???------Yes the GT 175 has the tuned exhaust.----And you must be aware of propshaft verses crank power ratings.--And you must be aware of marketing.----You must be aware of rebadging to clear out old inventory.
Heywire77
Ok does anyone have the testing procedures for no spark
Heywire77
Does anyone have the procedure for no spark to test
