Re: 1988 Johnson 150GT Bogs down badly after 15 minutes
would suggest load test on the battery, if it is in good condition it should run the engine for a rather long time if the engine is not charging (i have driven V8 powered vehicles 60+ miles with failed alternators/generators without issue on a fully charged battery. what makes me curious is that most outboards I am familiar with have magnetos and don't need a battery after start up.
things that would be on my checklist include
Fuel tank vents, are they open, are they plugged. 15min of operation would create a rather large vacuum in a tank that was sealed, enough so that the fuel pump could not draw against it.
for that matter is the primer bulb flattening while in operation staying rock hard, or anything else.
Water stream, is the pisser (water indicator) working, and is it putting out a good stream when the engine is cold then slowing up as the engine gets warmer. I have found this easiest to read when at an idle.
how hot are the heads and block getting, perhaps you have blockages in the water jacket(s) that are causing it to overheat and lose power.
do you still have spark on all cylinders when the problem manifests it's self. could be a failing coil. loose connection heating up after some run time.
others will be more helpful i am sure, there are many far more knowing than I.
the more information giving regarding your problem the closer they can narrow it down.
Sean
