I have had similar problems recently with a 15. Posted it here but don't see it. Anyway, mine had a steady stream at all rpm, but was getting hot but still ran fine. Took out the water pump and could not believe the hard old impeller that looked a 1/3 smaller than it should be and the vanes had taken such a set that it could not have been pumping as it should. Just ordered a replacement kit. The pump had sealant gasket material all over it and I wonder if that sealant helps to keep water pressure in the pump??? I have never used any sealant on many water pumps I have replaced of all brand outboards. I think in some OMC repair bulletins I have seen in the past it says to use gasket sealant. Never has any problems without it but maybe it is a good idea???
