1988 Johnson 140hp v4
bcaBomber
I just recently bought a fish and ski boat and it has a 1988 Johnson 140hp v4 2-stroke and I'm having a couple problems with it.
First: When I unload the boat of of the trailer it starts right up no problem. When I shut it off and try to start it back up it won't start. The motor is turning over but not firing. I changed the spark plugs and cleaned the spark plug connections and it is still having trouble. I have noticed that if i don't use the choke when starting it the second time, it is more likely to start. Could this be a carb issue causing too much fuel to flow flooding out the engine?
Second: When giving the boat throttle after exiting the no wake zone, the rpms will increase, but when it starts to plane out the motor winds up and acts like it is in nuetral. I am thinking either a spun prop or clutch dog problem. I have a spare prop so I will change that either way. Is it possible to switch the forward and reverse gears to fix this problem?
I
flyingscott
If there is no bang when the rpms climb probably a spun hub. No you do not want to switch the gears around!! Are you using the high idle lever when.you are starting it.
flyingscott
You can do a compression and spark test on it. Or it may be just figuring out how.that motor likes to start warm.
