Re: 1988 johnson 120...won't turn over
Ok, Joe. I did as you suggested and put the red lead on my multimeter to the S terminal, and grounded the black lead to a screw on a nearby door frame. I got maybe 1.2 volts. I also suceeded in blowing the main 20 amp breaker, and I tried to turn the flywheel clockwise to get the starter bendix to let go, but didn't do any good. I turned the starter bendix clockwise to try to make it screw back down to no avail. So I'm led to believe that there's no power getting from the keyswitch to the solenoid and starter. New keyswitch? I also checked for voltage cut off switch, and there was none. I then checked for voltage to the "B" battery terminal and got 1.3 volts. As I said in my first post, I'm no mechanic, and I'm certainly no electrician. I don't know what I did to blow the main fuse, but it blew, and I'm still left with the problem that the key won't turn the engine over. It's kind of frustrating when you don't really know what you're doing, but thanks especially to you and Kryptonite for all your help. I really do appreciate you for the advice.
