Re: 1988 Johnson 120 hp idles to high and misfires
Get yourself a spray bottle and put some premix in it. Throttle the engine up to the point where it starts runnin' ragged and then give the carb a little shot of the premix. If the engine smooths out and runs like it should for a few seconds, you've got a fuel problem. If it floods out immediately, the problem is probably an ignition breakdown. My bet is you have a partially plugged orfice in the carburetor. Do the deal with the spray bottle and post back (on this posting, not a new one) and tell us what ya found out
Also might wanna run some carbon cleaner thru it. Then change the plugs. I doubt it is a fuel delivery problem, but maybe.The timing may be out. A reed may be staying open too long. It may be a bad plug wire (best detected visually on a dark night--look for arcing)...But do the cheap stuff first.
Also, check the fuel pump filter.When idling ruff, try a shot of WD40 in the carb to see if it picks-up slightly.At least this may help you determine which carb is giving you grief.
