1988 Johnson 110
met128
My motor shorts out a coil when the cover is on. I just replaced the coils, Wires, CDI pack. Now I can't get the motor to run right with the cover on. Has anyone seen this problem. I have moved the plug wires every direction, still shorts. Any suggestions would be helpful. :confused: :confused:
ob
Re: 1988 Johnson 110
You apparently have a fitting on motor cover either touching or very close to coil wiring or sparkplug leads causing ignition to ground.Maybe cover latch .
