AEROCOOK
Master Chief Petty Officer
Thread starter- Joined
- Jul 28, 2004
- 872
My 1988 Johnson 110 (J110TLCCA) has been plagued with an intermittent misfire for the last 2 years and I'm hoping someone can help me diagnose the problem.
The motor idles perfectly at 800 RPM but as I accelerate, it starts to shudder, if I continue to advance the throttle, it will eventually hit on all 4 cylinders and take off. The same shudder occures when I back off the throttle from high speed to half throttle or less.
Suspecting that the cause was ignition related, I took my timing light with me on my last outing and here's what I discovered... The 2 starboard cylinders provided a good consistent strobe with the timing light pick up clamp loosly fitted over the plug wires but the 2 on the port side wouldnt strobe unless I physically held the plug wires tightly against the metal pickup on the clamp. Given these results, am I safe to assume that I have weaker spark signal on the 2 port cylinders? If so, would coils be a likely culprit? I have the factory manual for the motor and it states that you need specialized equipment (Merc-O-Tronic or Stevens) to properly test the coils, but before I even go there, do you think I'm on the right trail?
