AEROCOOK
Master Chief Petty Officer
- Jul 28, 2004
- 872
Hi all. I have a 1988 Johnson 110 and for whatever reason, I cant advance the timing to the required 28 degrees BTDC. The timing rod adjustment block is set at the maximum position and all I can get is about 25 degrees BTDC. To me, a logical solution would be to bend the rod a little bit to effectively shorten it and allow the timing base to advance a little bit further. Any thoughts on this? Is there a better or easier fix?
