1988 Force 85hp Prop Selection
jimdipiet
I am having trouble locating a propeller for my 1988 85hp force outboard(17 ft bayliner bass trophey). I don't want to go by the one that was on the boat because I was told it was the wrong prop. Does anyone know the best website to track down a propeller or the correct propeller? i do use the boat to water ski.
MGuckin
Re: 1988 Force 85hp Prop Selection
If you post your average loaded weight, hp, WOT RPM, and what your prop is now, we can give you an idea of what prop you should run. Or you can try this link. Starting Point For Prop Size
