1988 Force 85 hp Fuel Issue? Pulsating at WOT
dngbt5
What I have:
1988 Force 85 hp On a Bayliner Capri 1700 (856X8A)
What I have done:
-Checked compression 125 on all cylinders when cold
-checked all ground and ignition wires for solid connections
-replaced Trigger
-replaced all fuel lines and bulb
-checked for spark - have good spark on all cylinders
-replaced fuel pump diaphram
-removed and cleaned all carbs and replaced needles.
-checked and adjusted timing.
My problem:
-When I first get on the water, my motor starts and idles perfectly. It takes me about 10 minutes of idling to get to the wake zone. When I get there I can hammer down plane out and run @ WOT for about 2-10 minutes depending on the heat and my load in the boat I believe. After letting it sit or idle for a few minutes the motor will take off great at WOT and planes out, but then boggs down after 20 seconds or so. I can then return to 3/4 throttle and it runs fine as long as I do not increase the throttle past 3/4 throttle, If I increase the throttle past ?, the motor boggs again. If I leave the throttle at WOT too long it completely fouls the Top #1 cylinder and can no longer even run at 3/4 throttle. After checking all three plugs it is only the #1 Plug that is very dark and dirty.
- I have been told that one coil could be heating up and failing. At the end of the year last year I took it out by myself (light load and colder weather) and the motor held up for twice as long as it did with heavier loads and warmer weather.
-Could I have a float sticking?
-Cracked/Brocken Reed ( I inspected them when I removed the carbs but forgot to look underneath with a mirror and light)
I posted this under a different title early today and NMShooter mentioned I should try switching the Coils and that maybe a needle is not seating correctly. I forgot to mention in my other thread that I replace the needles and that I did just that with the coil. This was my response.
Thank you NMShooter.... I forgot to mention that at the end of the year last year I did exactly that. I switch coil #1 with #3 and the #3 plug looked to be the problem then and fouling. Today I got a new coil in the mail right after I started this thread. I installed it and hit the water immediately.
Here is what happened. It started perfectly and idled perfectly out to the no wake zone as before. I hit throttle slowly to WOT and it planed out for 3-4 seconds then it began to pulse. I realized I hadn't pumped the bulb on my fuel line so I killed the motor pumped the bulb and took off. I ran at WOT for about twenty minutes. Slowed to an idle for about 5 min and took off again at WOT for another 1-2 mins. After that I figured I stopped and started 5 times like I would if I was pulling a wakeboarder. She did great until the 6th time. At that point she began to pulsate. It seemed like one cylinder wasn't getting enough gas. I left it running and pumped the bulb to no avail so I shut the motor down and opened the cover. I didn't see any problems so I pumped the bulb again while the motor was off. I started her up and she ran perfect for another 5 min. I did the start/stop thing again with the same results. About the 5-6 time she failed again. I shut it of and pumped the bulb then she took off and ran perfect again until I did the start stop thing again. I repeated this one more time with the same results.
Could I be getting air in my fuel line. I found one place right before my fuel pump that looked like it was a little blue/wet with fuel. I do not have a clamp on this line and that is the first thing I am going to do tomorrow. I have checked my tank vent.. It is clear.
When I pump the bulb while the motor is off, I can hear fuel spraying/leaking out and I can see fuel leaking out. Is this just an overflow that should be there or is there a problem somewhere.
-could one of my needles I replace be bad?
_could I be sucking air into my fuel line?
roscoe
Re: 1988 Force 85 hp Fuel Issue? Pulsating at WOT
I'm betting on an air leak in the fuel line.
All lines should be clamped.
If in doubt, replace the lines and get clamping.
Could also have a sticking float.
jerryjerry05
Like Rosco says.Possible leak. Any inline connectors??
They leak and can suck air.
I had 2 of them on my motors when new.
That's the first thing I changed.I removed them and ran solid lines.
Top of the Force forum is a post by FrankA Called a linc and sinc.
When you squeeze the bulb there should be NO leaks.
The carbs have an overflow.If it comes out the overflow then the needle/seats are dirty,clogged???
The spray noise could be gas going into the carb.Once it's full and the bulb hard it should stop.
Check the gas for water.Install a water/fuel seperating filter.
I install a filter between the carb and pump.Wally World.G12 or G2 depending on hose size.
dngbt5
Going to work on this stuff today thank you both for your help. There is definitely noise associated with the carbs filling at first but after the bulb gets hard and I continue to squeeze more fuel is definitely leaking out. Hopefully I can solve this issue today.
One more question. I was wondering if anyone know if there is a filter on my in-tank fuel pickup? Maybe this is becoming clogged also?
dngbt5
Today I removed the carbs, cleaned them again, and checked all the floats/needles. I re-installed everything and the fuel bulb actually stays hard and there is no overflow of fuel. It looked like one of the needles was installed incorrectly (needle spring not under float tab). Probably my fault for getting in a hurry to get back on the water. I am planning on hittin the water tomorrow and I will let ya'll know how it goes.
yantot
Hi, I used to have a 1987 85hp Force with the same problem, it took me a while to figure out that the problem was the fuel pump diaghram. Buy the original one which is more flexible (rubbery type) than reproduced which is less flexible and tears easily. I know that you already replaced the fuel diaghram but it wont hurt to recheck and its cheap and easy to do. Good luck on your motor. Let us know if you fix it.
NMShooter
Sweet! Fingers crossed. Give feedback please.
dngbt5
:) I ran the boat today and it may have been the most rewarding trip I have ever taken. I believe that much of the work I did before this was definitely not a waste of time or money. I know there were multiple electrical issues I fixed but If I learned anything from this, it would be to: 1. get on this website and create your own thread explaining your situation, 2. take your time and double check your work before moving to the next possible problem. I spent a long time reading old threads relating to my issues and working off of them but it only took me a few days to eliminate the most recent problem I had after starting this post. Thank you all for your help and especially jerryjerry05 for explaining the carb/needle issue. Gotta throw a shout out to NMShooter also for all the help and info. I pray this is the last time I have to get on here to find a solution to my problem, but I promise to do my best to keep checking threads and helping anyone else I can :)
dngbt5
Ok I took the boat back out today and was very happy for a couple trips around the lake. After starting and stopping a three times I took off again, the boat planed out I slowed to a crawl for an on coming fisherman and took off again. She once again planed out again but after a few moments the motor began to pulsate and lose power. I stopped, removed the spark plugs and the third cylinder looked dry compared to the other two. I took off again a couple times with the same results. It definitely seems to be a carb/fuel issue.
What could be causing this problem?
Seems that this float/needle is sticking to me?
I have replaced the fuel pump diaphram. Is there anything else I could do with the Fuel pump? Needles to clean/replace?
dngbt5
I removed the carbs, cleaned them, and check to make sure all needles and floats were working correctly. Everything looked good. I also checked out the linc and sync thread from Frank A and followed his instructions to the T. Also I adjusted the timing and have it set to the single mark at idle. There is a triple III mark also but it didn't seem that I could even adjust it to that point. Is the single I mark correct at idle? I took the boat again yesterday after working on it again and it ran great. However, I was by myself and there was no load on the boat. Today I took it out again and had three friends in the boat and it ran good also, It was a little slow on the whole shot but I probably had about 800 pounds in the boat at the time. I was really proud of the boat and then another buddy showed up and he weighs about 230 himself. After he got in the boat I took of and it took a little bit but the boat planed out, but soon after maybe 20 seconds the boat once again began to bog and lose power. If I stopped for a few seconds and took another whole shot it would once again plane out and then bog. Seemed to be losing one cylinder. I checked all the plugs and they all looked the same (pretty dark wet and dirty, but they always have been) none were dry as the number three had been previously. I am thinking I am running the carbs a bit rich, and under the heavy load I am fouling a plug. I have the turned the jets to about 1 to 1&1/4. I am a little worried that the guy who worked on this boat before I owned it over tightened the screws and may have damaged the seats as they were all the way closed when I got the boat and it still ran. I am scared to closed them any further as Frank A says not to close past 3/4 and most people have said 1 to 1&1/4 works good.
I have replaced the screws themselves and they seem to be a little loose ( they turn very easily and am worried they may vibrate open or closed) Could this be my problem. It sure seems to be a fuel issue to me.
