1988 force 85 hp carb prob
mauiboy
hey guys
i think i screwed up i stated it this morning but was running ruff i then shut her down and readjusted the low idle screw to 1 1/4 turn out from lightly seated now the darn thjng wont start or even want to . tried starting fueld and still nothing.
my1stboat1
Re: 1988 force 85 hp crab prob
1 1/16 to 1 1/4 is the proper adjustment from a lightly seated position if it was running before and isnt now you most likely flooded the engine. Remove the plugs make sure there clean and dry and not soaked with fuel if they are replace them and recheck run. also make sure your tether button is operating
mauiboy
tHANKS iLL TRY THAT Ill let you guys know ib the outcome
mauiboy
Re: 1988 force 85 hp carb prob
Thanks My1stboat
It was the swich that conects to the key, never thought about that
