1988 force 50 frustrations!!! please help!
cron416
This site is awesome !!!
ok I have a 1988 force 50 hp, I was not getting any spark to the bottom cylinder, thinking the coil may be shot I first swapped out with the good one and it would crank and backfire so I changed out the coil, plug and wire now with the new coil im getting backfire as i did when i switched it out so I think the coil was bad, however I still cant seem to get that bottom cylinder to fire, compression is 120 in both cylinders so thats ok. Any suggestions?????????
lunaticford
Re: 1988 force 50 frustrations!!! please help!
You may have a bad cd module or possible bad trigger I am fighting with the same issue
cron416
how did you make out with your motor, did you resolve the issue? Was just wondering what it was if you did get it fixed.
Nitefire36
I have the same thing wrong with my 50 hp .I changed the top coil to btm and re wired for btm plug , it backfired like yours ,then i realized i didnt move the 1&3 and 3&4 coated wires had to be moved if you didnt move, the timeing is off and you get backfire.after that i replaced the trigger and bought a new coil with pack ,cost was about 320.00 its all back to working now
