1988 force 50 chugging at idle
juggnasty
i rebuild the carb and fuel pump clean recirc system and replaced head gasket. checked reed plates but the only way it will idle good is if air screw is turned all the way in ? and suggestion will be appreciated thanks.
juggnasty
Re: 1988 force 50 chugging at idle
also it slowly dies when cowling is placed on
tater76
I guess its a matter of elimination, as Jerry says, check compression and spark. If you have those then your carb rebuild may be botched (as I have done). Its amazing how little the dirt it takes to screw them up.
juggnasty
motor is like new still has cross hatches in cylinder with 140 compression on both.. i have nothing but trouble on outboard engines its just not my thing i guess
TwoFish
If it idles OK with the cover off and only dies when you put the cover on I’d be looking for an exhaust leak. The exhaust gasses may be filling up the cover and chocking the motor.
