1988 Force 125HP head bolt torque?
richb420
Hello, can anyone tell me what the torque setting is for the head bolts on my 1988 Force 125hp? I am replacing the head gasket.
Thanks For All The Help,
Rich
baxtr
Re: 1988 Force 125HP head bolt torque?
cylinder head 225 in lbs out of Seloc repair manual
richb420
WOW, 225lbs, thats more than whats on my wrench. My wrench only goes to 150lb of torque, I will have to go and buy another one.
Thanks,
Rich
Kajun37
force manf. manual says this... "torque bolts in sequence to 75 inlbs: then torque 50 in lbs at a time until bolts are torqued to 225 + 5 in lbs"
torque sequence:
17 18
13 14
9 10
5 6
1 2
4 3
8 7
12 11
16 15
roscoe
Thats INCH lbs, NOT FOOT lbs.
225 in lbs = 18.75 ft lbs
richb420
CRAP!! I WISH I KNEW THAT AHEAD OF TIME, I JUST SNAPPED A HEAD BOLT!!! SO NOW, HOW DO I REMOVE THE HEAD BOLT? ALSO, CAN I JUST GET ANY BOLT TO REPLACE THE BROKEN ONE?
roscoe
You "could" use another bolt, but you SHOULD go to Mercury and get the right one.
You are gonna need a new head gasket anyway, as that one is probably crushed beyond use.
Subject of broken bolts has been discussed many times.
You can try the search feature looking for "broken bolt" or "bolt removal".
Removal depends on condition.
Drill it, then easy-out bolt remover.
Or weld another bolt onto it, then turn it out.
Or drill it out and re-tap the block.
richb420
Thank you guys for all the help. I was not thinking straight when I tried to tighten the bolts down. I was a little out of it considering both my cars were broken into the night before. I will order a new gasket and new bolts today.
Thanks,
Rich
