ahickman
- Jul 5, 2012
- 79
When taking the prop off to adjust the timing/idle in a barrell last week, I quickly noticed that the previous owner had used a brass nut to hold the steel prop on. This nut when removed, crumbled in terms of the inner threads. A few questions for anyone regarding the prop nut and shaft:
1. Is the nut supposed to be brass or other softer metals?
2. Many years ago when I had smaller motors (Evinrude 25 HP, etc.), the prop shaft had a shear pin which would allow the propeller to spin freely if run aground or similar damage. This engine has nothing to relieve the prop in such a way. Is this correct?
Thanks,
Aaron
Thanks,
Aaron
