Re: 1988 force 125 outboard tilt/trim problem
http://home.comcast.net/~netsvc/Images/Main/CF_P3B.jpg
picture of 3w motor. wires directly to switch. No relays.
http://home.comcast.net/~netsvc/Images/Main/CF_P2B.jpg
picture of 2w motor. wires go to engine. relays mounted on pan near starter wires.
if you have a 3w motor then it has a 6' cable tail. Find the end of cable and check voltage. If you are getting voltage but motor does not spin then you need a motor rebuild. No point taking it apart until you are prepared to do the job correctly. At the very minimum you will need brushes, gaskets, springs, a pair of #10 bonded sealing washers, and a 6' whip of 12/3 SJO cord. If oil or water is inside motor then you will also need 1/4-20 flat head screws, permacell fabric tape (P212HD), some mineral spirits, and a 1/4" cobalt drill bit. So that you can remove and retape the windings. By using permacell tape you don't need to get fishpaper insulating sheets. If inside of motor is rusted then you will also need a bead blaster, a vat of phosphoric acid, a bucket of chem-dip metal prep, a can of zinc or z/c waterproof primer, and a pair of throughbolts (i think they are 10-24 x4.5" SS pan head).
This is definitely a case where you should either do it right or don't bother. Everytime you mess with the oil tubes is one step closer to having stripped out ports. So motor/pumps should be done once, done right, and not messed with again for another 20 years.
