1988 force 125 issues
bgsou53
Just when I finally feel like its running good, disaster strikes, and by that I mean me:
Finished up with the link & sync last weekend, moved onto timing. Timing checked out, but when removing the temporary ground I used to ground the plugs out while checking static timing I forgot to tighten the bolt back up that grounds the panel to the block, when I took the boat out the bolt eventually rattled out completely and the engine died.
Once I got it home I quickly found the ground dangling and reconnected it, though it still would not start. Knowing how sensitive the electrical systems can be I proceeded to check for spark with a spark tester and fuel disconnected, I found that I had no spark on cylinder 2, and a visibly weaker spark on cylinder 4 than 1 and 3. Before I jumped to any conclusions knowing I had some issues with crappy connections and wires breaking off completely at the terminals, I went through and put new spades on every single wire, one terminal at a time as to make sure not to mess up their locations.
After doing this I gained spark on cylinder 2 again, roughly the same as 1 and 3, but did not gain anything on cylinder 4. Still I thought 3 strong sparks and -some- spark on 4 I figured it would at least start even if it didn't run well. I can only get it to very briefly sputter and stall. I have double and triple checked that all wiring is where it belongs.
I am at a loss, seems unlikely to have a completely separate failure at the same time, but I'm open to suggestions?
bgsou53
I never removed the flywheel, Was I supposed to? I just re-read the link&sync directions and don't see it necessary to remove the flywheel in any of those instructions... in any case, nothing should have changed there as I didn't remove the flywheel..
jerryjerry05
The key can shear without doing anything.
New boat in 88 had twin 85's
Went fishing and tried to restart the port motor.
Nope, no matter what I did it wouldn't start.
Luckily I worked where I bought the boat.
Top mechanic said check the key.
Sheared
bgsou53
I will check this tomorrow, Thanks for the advice. will let you know how I make out
