ahickman
- Jul 5, 2012
- 79
Re: 1988 Force 125: Carb rebuild and timing set needed?
Just got the tachometer in from ebay purchase. Wound it around spark plug wire #1 a couple of times and set it to 2 according instructions above. Ground the white wire on the chassis. Adjusted idle screw until I got about 1100 RPMs in neutral with the prop in a large tub of water. I started adjusting the air/fuel mixture, but got intimidated because I was not quite sure what I was listening for. Lots of blue smoke and got annoyed. Questions are:
1. Do I adjust one carb at a time, turning 1/16 a turn at a time and listen for a rise in idle each time?
2. When it get to a rough idle, I back it off and then go for the other carb?
3. Should the smoke clear as I get closer to the right mixture????
