1988 evinrude T-Stats upgrade from control valve
Jappryor
good morning to all, i just joined this form a few days ago and i really need your help. i know this topic has been discussed before but i can not find a start to finish thread on how to do this or what parts is needed on this up grade. i purchased a 1988 laser ski boat with a 1988 evinrude 200 back in july 2015, got stranded on the water 4 out of the five times i gotten to take it out. learned the fuel cap was letting water in the fuel due to not being the original fuel cap. i got lucky and found one on ebay from a vintage dealer. then all my electronics caught fire so had to save up and i replaced the stator, power pack and voltage regulator. the guy i bought the boat from he had a electronic fuel pump, so i rebuilt the original fuel pump on the motor. was going to take it back out to test run it again. now i have a water leak from the control valve that is hooked to the throttle linkage. after researching that i find out you can no longer buy that part. so i find you can do an up grade to bypass the control valve. but can not find a thread from start to finish on what all is needed and how to do this upgrade. so please help me out, after all the repairs i have done i believe i will have a good boat and motor that will last me a long while.
thank you John
Jappryor
i want to thank you replying i have searched his name every way possible i think. i may not be doing something right. i am going to keep searching and see if i can find his post but thanks again for replying and helping
Faztbullet
The modification involves removing the flow control valve and all associated water lines, and removing the thermostat covers and diaphragms. You'll then install thermostat covers, springs, and gaskets from a 1990 70 hp engine (you can use the existing thermostats).
rte203
Please forgive me for the High Jack , I'm having to make this same change, I didn't see a spring in My 1990 225 But what order or where does the spring go ? Cover, Gasket , Thermostat, then Spring?
