Hi guys I am sure one of you can help here so thanks in advance. I have a brand new battery in this motor and recently got the old fuel cleared out and the motor back to full throttle BUT now the anchor and bow lights are super dim and bilge pump won't come on and starter is barely crankkking. I am hoping this is a simpler grounding problem but did already clean up the terminals and wires on the battery side. Where else should I look to be cleaning for corrosion and knock out some of the easy stuff before I start accusing the starter or rectifier or stator? Any simple multi meter stuff I could be doing for this isssue? Batteries show 12.6 volts. Thanks
