fmrodrigue
Thread starter- Joined
- Sep 4, 2007
- 11
I am trying to purchase a boat and motor 1988 70hp evinrude vro if I can get it to run. Problem is the owner let sit with fuel hose hooked up for over a year. Tried carborator cleaner first and it cranks and runs for 30 seconds at high idle only 2000rpm then just dies. I took all the carbs of went through them and cleaned them bowls and floats and jets didnt look that bad. re bolted carbs and cranked up but still had the same problem. I can choke the engine right before it kills to keep it running. It seems that it burns the gas out of the bowls and wants to die. So I took apart the fuel pump and cleaned it it didnt look like it was varnished to bad so I cleaned it and re assembled (the diaphram looked ok and was flexible), Cranked it and it did the same thing. The bulb on fuel line stays tight and when forced squezed it still dies after 30 seconds. checked plugs they are new and dry, changed in line fuel filter and still does the same thing when cranked. I am thinking about bypassing fuel pump and hooking direct to fuel line and squezzing bulb to see if I can get it to run longer which will answer a faulty fuel pump. all hoses are clamped and in good condition. Any sugestions would be greatly appreciated.
