1988 Evenrude 88 HP
aldennis
I have a 1988 Evenrude 88 hp on a pontoon boat. I was told by the previois owner that it was a gas hog. My experience so far seems that is true. I know that fuel comsuptions is widely varied depending on your use. Is their some type of chart that would indicated fuel comsuption based on throttle position? Also, is there anything I can do to improve fuel comsumption? Other than new plugs and carb adjustment?
Thanks,
Al
D
DJ
Guest
Re: 1988 Evenrude 88 HP
The best thing you can do is to make sure it has the right propeller.
The engine should be able to turn 5500 RPM with a moderate load. Any less and you are lugging it and pouring gas down the drain.
D
DJ
Guest
What is best way to check RPM?
Thnaks
Al
With a tachometer. You can use an automotive inductive test tach. However, you'll have to find one that can read 11,000 RPM plus. Then half the reading. The reason being is that is a 2 stroke engine and fires every time the piston goes to TDC.
