1988 Bayliner Capri. Has a OMC I/o motor. I have the key switch and emergency shutoff switch off the dash so I can access the wires. The key does not start the boat. I can hook the power from my radio to either the pink wire on the key switch or to either pink wires on the shutoff switch and the dash lights cut on and I can turn the key and it will start the boat. The key however will then not turn the boat off. The connection between the wires must be broken to shut the boat off. My dash lights do not come on when the key is turned on but my blower and trim do work. Is my ignition switch bad? Is my ignition coil bad? Can someone please tell me what's wrong
