robrexgrant
Thread starter- Joined
- Jul 27, 2011
- 2
I recently swapped out GM 305 with 350. Everything seems to be workig except for power to the bilge pump. Traced back to a connector, no power there. The toggle switch tested good. All other instruments and electrical work fine. Is there a fuse somewhere for the pump? Another mentionable, I switched from a Motorala 3 wire to a powermaster 1 wire alterator. Not sure if that could be the culprit? Any help would be much appreciated!
