1988 Bass Tracker Tournament TXS 17ft Questions
Nebraska
Hello All!!
I purchased a used boat and have some general questions as I am new to boating. Any help will be greatly appreciated. I recently removed the floor of this boat and installed new wood and carpet. I am getting ready to finish the top deck but wanted to make sure all the wires were good first. On to my questions!
When I turn the key to what would be the same as a auxillary position in a car I hear a "beep." When I switch the lights on though or the radio nothing happens. I cant imagine this boat needing to be running for those to work? All the fuses are good and Im going to continue trouble shooting but wanted to make sure I was atleast sending power to the fuse panel.
Also does anyone know of a good place to obtain a schematic to double check everything against?
And for my final question, Does anyone know what the "S" is for in the TXS? I have noticed the TX model is fairly common but dont see the TXS alot?
Have a great day everyone!
Silvertip
Honorary Supreme Mariner
Re: 1988 Bass Tracker Tournament TXS 17ft Questions
There is no accessory position on an outboard ignition switch. The radio may be wired to the "A" (accessory) terminal on the ignition switch which also activates the gauges. If that's the case the key would need to be in the RUN position for the radio and lights to operate. That is NOT the way it should be however. Normally there is a separate red and black wire (#8 or #10) running from the battery to the fuse panel. That powers all accessories (but not the gauges). There should be a circuit breaker or fuse near the positive terminal of the battery. If that fuse or breaker is open, or if the wires are not connected, none of the accessories will work. Gauges are powered from the ignition key "A" terminal.
Nebraska
Thank you for your insight. I will do a little trouble shooting and post the findings.
Nebraska
Everything seems to work off of the Deep Cycle battery which I did not have installed yet. I installed this and everything worked when you moved the wires around the panel. Can anyone suggest a good place to get a fuse panel and can I change it over to the newer plug in type fuses? If I can then how do I know which fuse size to put for each function? Interior lights, nav lights, depth sounder, aerator, bilge pump, radio?
beagleboy
Fuse block or if you prefer inline fuse holders are available at auto supply store. You have to figure out for example how many amps your radio draws add 10% and thats your fuse size for the radio. Certain items you want dedicated to a circuit alone such as nav lights.
Nebraska
Is it possible to get the amperage using a multimeter? If so what setting and what should I do? Thanks again guys!
beagleboy
Your radio for example should have a label indicating amperage. When it comes to lights you can put an amp meter in line and see how much it draws or use the formula of volts x amps = watts. your voltage will be a given. Watts will or should be printed on the bulb. Divide watts by volts to give you amps.
