1988 90HP Compression Issues
Joe in Indy
I just bought a Four Winns with a 1988 90HP Johnson Outboard. I know very little about engines, but was told it ran great with the exception that when it was cold it sometimes died when in idle, but when running there seemed to be no issues. I brought it to a mechanic and he said I had compression issues. I was told that it was showing 80 - 90 - 100 - 80. Am I completely screwed or could I get a summer or 2 out of it?
Bosunsmate
I
Depends how many times you use it, ive seen these things run on broken rings for ages, they just carbon up. Eventually something goes but this can take quite a while so long as you dont run a ring free/sea foam through it.
If you can handle it dying occasionally in idle and you have a kicker to get you home then theres always that option of keeping it going.
You can also adjust the timing so that it is a bit faster at idle and less likely to die
Ibl0wstuffup
I used my 97 115 for two years with low compression on one cylinder. A couple times it wouldn't run at low enough rpm to do no wake speed into the harbor so I docked with my electric trolling motor. I didn't trust it enough to go farther than I could get back on my trolling motor though. I also only went out when it was calm.
emdsapmgr
The general rule is that normal compression can vary up to 10% between cyls. Yours variance is off 20%. Bears looking into now-before it fails and you get stranded somewhere. Pull both heads and have a look inside. Post pictures.
Joe in Indy
Thanks for the advice - as soon as I can get it back from the mechanic I will give these suggestions a try & post pics.
Thanks again
boobie
Go to a parts house, rent a compression gauge and check the compression yourself. There are good mechanics out there but some I don't trust. I worked with a lot of bad ones.
