1988 88hp Johnson Outboard Sputtering/Coughing at Idle
gholman12
Had this boat for a few years and it's slowly developed this cough at idle. I've tried increasing the idle, and that works to some degree, but then it is idling too high. It's an old motor and hasn't had the carbs rebuilt in at least 5 years, do you think it's gummed up carbs or some kind of misfire?
Thanks in advance for your help!
boobie
Start with a compression test and then look into the carbs.
V153
Sounds like it's running on about 1 1/2 cylinders. Check compression and spark first. Then rebuild the carbs.
