Hey everyone,
I've got an 1988 85 hp Force outboard that has had shifting issues since I got it 3 years ago. I've been through the entire shift system from the control units to the shift rod seal in the lower unit adjusting and replacing parts. I'm all too familiar with the whole system at this point, except for the inner workings of the lower unit. Every time I think I've got it fixed a new problem rears its ugly head.
At the beginning of this season, I had it so that shifting into both forward and reverse was smooth as butter and everything worked great. Had a few good days on the lake, thought I had it licked, and then this. At about 3/4 throttle the boat now starts banging every few seconds as the gears skip teeth. I've tried biasing the shift rod adjustment nuts at the top of the shift rod towards forward. They're now at the point that reverse barely engages and the popping out of gear is less often but is still happening.
At this point I have to believe this is one of two problems... either the gear teeth are worn/rounded and are slipping or the shift dogs are worn and not holding the gears in the engaged position properly. I'm hoping against hope that it's the second issue for two reasons: 1) it's the easier and less expensive fix, and 2) when I replace the lower unit oil, I don't find much metal in it... just a little bit of very fine "glitter" which, in my experience, is fairly normal in most lower units.
I'm not familiar with what is involved in removing the shift dogs and I've done some reading here about some people grinding them flat again (since new ones don't seem to be available). Could some of you with more intimate knowledge of the inner workings of the lower unit shed some light on the process of removing and grinding the shift dogs? The more details the better. I'm a fairly handy guy that's spent a lot of time working on boats and cars, so I'm hoping I can get this done on my own. Many thanks in advance!
Mike
Mike
