1988 60hp johnson
okparton
Is there a place where I can download a diagram and instructions for replacing or repairing the water pump?
HighTrim
Re: 1988 60hp johnson
As Tash said, get yourself a manual. It will pay for itself a million times over, trust me. Check www.ebay.com or www.outboardbooks.com for a factory reprint.
The following video may be of some help.
http://www.meegsonline.com/tmd/waterpump.wmv
Other things to mention, you will need a can of gasket sealing compound. I use BRP's brand with the built in brush in the lid. A tube of marine grease for the drive shaft splines (and prop shaft splines, I remove my prop when I drop my lower unit to ensure I do not damage it, as well as to grease the splines and remove any fishing line from the prop shaft.)
