1988 30hp johnson mo.j30telcce
bduane
need to get the carb off this thing,how do I take the starter off so I can get to the carb mounting nut? anyone? thanx
AlTn
take the starter and bracket off as one...then remove the starter from the bracket
bduane
I had the bolts & nuts off what the bracket should have been, but nothing moved. Looks to be all one with the head
Honorary Supreme Mariner
No, the bracket comes off with just 3 screws / fasteners.----One nut on the front.---One bolt at the top on the side.----One bolt on the bottom.-----May have to loosen the tower shaft too.-----Then the starter and bracket slide forward and off.-----Nothing to it.
AlTn
on this model does the starter solenoid hide one of the screws?
