1988 28 HP Johnson won't run wide open.
Dacksy68
This weekend I went out in my boat, first time since 1st week in August. Motor idels rough and won't run wide open unless I put a couple fingers in front of carb opening. Could this be a problem with the fuel pump?
ondarvr
Re: 1988 28 HP Johnson won't run wide open.
the carb needs to be cleaned.
Haffiman
You have to remove the complete starter bracket with starter attached!!
