pitbull202_5@yahoo.com
Thread starter- Joined
- Jul 16, 2017
- 1
I just bought a pontoon with a 1988 28 hp Evinrude SPL & I don't know the last time it ran. I changed the lower unit oil which was still good before I changed it. So I know it has no leaks. I tried starting it but it wouldn't start & the starter wouldn't make a complete cycle. So I tried by hand & had no spark. I changed the spark plugs & power pack until I got a BLUE spark in both cylinders when pull starting it. I checked both gas tanks which 1 was cracked & the other 1 was good. Then I cleaned it out & I mixed 50:1 NEW gas & checked the primer bulb which is working. I was trying to start it with jumper cables in stead of hooking up a battery. Once I hooked up a battery, the starter started working properly so I figured that part out. The motor still won't start with the key even if I spray starting fluid in it. I haven't checked to see if I'm getting a spark when starting with a key yet so I will check that next. What else should I check next?
