1988 25HP Johnson - Can't get shifter to move
razrback
Hello, I really need some help with my outboard. It's a 1988 25HP Johnson, electric start, manual shift. Well taken care of, but the other day, the shifter would not go into neutral. I have separated the lower shift rod from the lower unit. I can cycle the gear shifter in the lower unit and tested by turning the prop that it's going into and out of gear fine. However, I still cannot get the gear shift lever control to move.
I really need someone to tell me where to start looking. I have a repair manual, but it doesn't give much info on this topic.
Captain Jeff
I'm not an expert on your particular motor but I have used a few of them. A couple things: make sure your RPMs aren't too high, you may not be able to shift out of gear if it is spinning too fast. Another thing; I remember those side shifters to be a little wonky with some good play in them. I would look at the linkage and where the lever mounts and lubricate everything, and see if you can tighten up the linkage so that you have the full force of your hand to push and pull on the shaft. Also check the manual for shift shaft adjustment. The shift rod is height adjustable by screwing it in or out on many motors, not sure on yours. You may need to tweak it but if no work was done on it then it shouldn't be out of wack.
jimmbo
Was the throttle backed off to the idle position?
razrback
Thank you. It ran fine down to ole fishing hole, but when i killed the engine it was in the forward position, which is where it is now. Since I can't get it to neutral, i don;t know anyway to get it started. I'll grease it up tomorrow and see if that will help.
razrback
I haven't tried to move the throttle, didn't think that might be the problem. I'm not an boater expert by any means, so I really appreciate your question. I'll try that in the morning
jimmbo
If the throttle is too far towards 'fast' there are interlocks on a lot of engines that prevent the shift lever moving into or out or gear
oldboat1
If you have a remote set up, could be an issue with the box or the cable.
With or without a remote, you might try pulling out the starter cord slowly, about half way -- just through a compression cycle. Then try shifting. (Prop should rotate a bit, possibly freeing up linkage.)
razrback
Jimmbo, you are the master. Man, do I feel like an idiot. Moved the throttle down to idle and viola, works like a charm.
