mcurcio1989
Thread starter- Joined
- May 30, 2011
- 40
This motor ran perfect when I put it away for the winter. Took it out this year and it seemed to run perfect but after 10-15min at moderate to full power it started acting up. Once it starts doing this it will still idle in or out of gear perfectly. Out of gear it will rev up seemingly fine. Rev it up in gear and it will die (Its not missing or running rough its almost just like you turned it off.) However, if you give it a little power than go hard to wot it will work through and hold it usually but at about 75% of the normal power it has at wot. To restart it you have to give it a shot of gas and it will fire right up otherwise it just cranks. Normally it fires right up when shut off.
I have gone through the carb thoroughly twice now with a rebuild kit and replaced the gaskets. This is fresh gas and oil. The carb has been very clean every time I have gone through it.
It seems that 15 minutes is to long for it to be a mixture issue that develops when the engine is at operating temps it. After this time the engine has been up to temp for some time. Also the only screw I can adjust on the carb is an idle needle and it is idling fine. It seems likely that it is an electrical issue I'm just not sure what.
Also the fact that you have to give a shot of gas for it to fire up again is odd to me.
