1988 14hp evinrude tiller to remote?
phatmanmike
i have a 1988 14hp evinrude 2 cylinder tiller motor. i want to be able to hook it up as a remotely operated motor. i understand how to do the throttle and shift, but ho do i hook up the steering, ? do i need to by a wheel, helm, and standard teleflex cable like my big boat has... if so it sounds pretty expensive. thanks in advance guys
OBJ
Re: 1988 14hp evinrude tiller to remote?
Mike...is that a 15hp yer talkin' about?<br /><br />Yeah...if ya' want to do the remote thing, you'll need to check into a steering system, 'round $185. You will need the steering whell also, 15 to $30. The steering kit will have all you need to mount it.<br /><br />You will need an adapter for the engine also. Can't remember what this costs' right off hand.<br /><br />Now if you want remote start, that will set ya' back another 400 roughly if I remember right.<br /><br />Hope we've helped a little.
phatmanmike
obj, no, its a 14hp, its a special model, was a comercial / special model similar to the 48hp and the 88 hp.. and i believe thats the only year for the 14hp. but thanks, your advice is always apreciated :) :eek:
OBJ
Yep...you are absolutely right Mike. Your 14 has asplit gearcase and the 9.9/15 don't. But everything else is darn near the same. And my previous post would stll hold true. (had to recheck the think tank!)
