FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
Check the vent screw on the top of your gas can. Make sure it is open when motor is running. Possible problems are a bad fuel pump diaphram or a bad primer bulb. Verify all fuel connections are tight. If you keep pumping the primer bulb do you see gas leaking from any of the carbs?
i have a permanent installed tank. is there a vent screw on it? the primer ball is new but it was purchased at wal mart. i heard they have problems with some of them. the fuel pump is about 2 years old. no fuel leaks that i can see.
Randy,<br /><br />I have an '84 force 125. I've been mixing 50 to one with no issues. <br /><br />Do not run that motor without mixing, you'll kill the power head in no time at all!
