1988 125hp force
gotsaved
when i pulled the plugs it seemed that one plug was steam cleaned. it seems water is geting in that cylinder. whats next.
12Footer
Re: 1988 125hp force
Yuk...<br />OK, first, check compression. If low on the cylinder, pull the head.Inspect surfaces and piston crown.<br />If compression is normal or close to it, pull the exaust port plate, and look for signs of leaking on the gasket and surfaces.
