1987 Yamaha 90hp ETLH timing
Blacklab
I've assembled everything from the head gasket up with new Yamaha parts (thanks to Iboat parts department and excellent advice given by several members in old posts) and been able to start the engine. No leaks when run in a test tank (a large new trash can) for a few minutes. I have hooked up an inductive timing light to cylinder #1 and at idle (about 900 RPM with the motor in neutral) the mark is at "0". The manual says 10 degrees +/-1. As I understand it, the motor should be put in gear. What is the approximate timing while not in gear. If I can do a preliminary adjustment before I take it to the water that would be helpful. Thanks in advance for your answers.
Blacklab
Re: 1987 Yamaha 90hp ETLH timing
I took it to the water and set timing to Specs. at idle and WOT. In addition I adjusted the idle speed to 850 RPM. Now if only we had a few more months of summer! Thanks again for all of the confidence to get down and dirty with my outboard. :)
