1987 YAMAHA 150HP OUTBOAD Compressor, 90-99 PSI,
mcgill
HELLO
I HAVE A 1987 YAMAHA 150HP OUTBOAD I ATTACHED THE Comreption metter to each cli, and i am gett Compressor, 90-99 PSI,is this good ,ok or bad.i did not do a wet compretion test.
robert graham
Re: 1987 YAMAHA 150HP OUTBOAD Compressor, 90-99 PSI,
HELLO
If all the cylinders are pretty near(10%) the same and the motor is running fine, then you're probably good. Maybe run some Yamaha Ringfree de-carbon through the motor? Are you having any problems with this motor that prompted the compression test?
mcgill
Hello'''
The motor will run good for 10 mui, then start to miss. soon it will stall out ,and you can not get it started untill it cools down. I replest all the igntion coils thay are the same one on it when it was built in 1987.
