1987 Yachtwin
bcc101
Along with a Paceship 23 we purchased and are presently working on we have an Evinrude E8SRLCU.
​This is a 1987 motor cosmetically in good shape. It did, however sit for at least 10 years before we purchased the boat.
During the winter I would like to do some work on the primer and fuel pump. Eventually get to the carb.
I have located some dealers that have rebuild kits for those components but have not found a source for fuel hoses- a couple appear to be shaped.
​Also just wondering if anyone has had any problems working on the motor.
Thanks
Bruce
bcc101
I just looked at the brp site. Very similar to some of the marine engine parts supplies sites. I was able to pick parts but not able to see if they were available and the price.
Also am curious if anyone has had experience working on this engine.
Thanks
Bruce
oldboat1
one of the shaped hoses appears to be available here at iBoats for $20 (PN 0331769). Beyond that, you should be able to find fuel hose of matching diameter at an auto parts store. Just go for additional length to avoid kinking.
experience with mid-80s 9.9s, but not the 8 -- notice the small square pump is used on earlier models of your motor, and a larger pump on later models.
Vic.S
Thanks
Bruce
I have an '84 6hp Yachtwin. Pretty much the same engine but a different carb with choke flap rather than primer pump
