1987 ProV 150 Carburetor Kit
Fortec Five
My first post here.
My Yamaha ProV 150 has three carburetors. That is "dual floats" in each carburetor. NOT single float as some might think. So, here is the "Big" question. What carburetor kit number?
All I can find from various marine firms that sells these kits show #6E5-W0093-06-00 is for a "single bowl" carburetor...with one float and parts, not the double bowl carb.
However, I did locate...Pro Marine #659306 kit (OE #6E5-W0093-06-00) with gasket(s) for a double bowl float carb. NOTE: it has two (2) gaskets that goes between the lower and upper carb sections. My Yamaha ProV 150 carbs only have one (1) gasket between the two sections.
If I buy the Pro Marine #659306 kit with the two (2) carbs gaskets, will I need to use the two gaskets from the kit?
Thanks for the needed answers.
flounderman
Re: 1987 ProV 150 Carburetor Kit
I have a '89 115 with the 2 float carb. I went to my local Yamaha dealer in Bellingham and purchased 2 OEM 6E5-W0093-06 kits for $32 each. There is only 1 gasket between the upper & lower components.
Fortec Five
Thanks very much. That seems to be accurate on what I can find.
