1987 Proline W/A Cuddy
seachest
Hello all, I have a '87 W/A Cuddy with a 140HP OMC Sea Drive- Unfortunately, my BIA Capacity Plate is unreadable and a spec sheet I received from Proline doesn't address the load capacity - I'm hoping that someone out there has a similar model and that you would be so kind to share the information.
Thank You in advance for any light you can shed on this issue.
tjhowell63
Re: 1987 Proline W/A Cuddy
I have an 88 Pro-Line 230 23' Walk Around. It's capacity is 9 persons or 2500 lbs. Mine is a I/O with a mercruiser 5.7 Alpha 1.
Hope this helps a little
