1987 PRO V 150 H Carb Setting
lilgambler123
I have a 1987 yamaha Pro v 150 i just took the carbs off and cleaned them they seem fine but i need to know how to set the floats, and how many turns out is the normal setting or a good starting point on the air screws. With the floats set and the air screws at a good starting point(HOW DO I DETERMINE WHICH WAY I NEED TO TURN THE SCREWS AND SHOULD ALL 6 AIR SCREWS BE TURNED THE SAME WAY. Also what is the trick to sink and link the carbs i have three. THANKS A LOT FOR ANY INFO.:confused: Control Code#6J9 L Serial# 303525 Model#PRO V 150 H
99yam40
Re: 1987 PRO V 150 H Carb Setting
looks like you need to pick up a service manual for your motor
